Sponsored by: CARiD
Limp Mode
Old Jul 22, 2017 | 02:14 PM
Meldav32's Avatar
Default Limp Mode
Hello all again!
today is a new issue lol ugh sooo as I was leaving a friends house my 03 Land Rover Disco 2 went into limp mode, (I didn't know what the D flashing and the lit up green S & M meant til I searched here) now I see ppl saying it could be all sorts of things? Last thing replaced on mine was the brake light switch and then right before that the Crankshaft position sensor. Now I did put it in park and cut my car off at the end of the driveway and waited a sec cut it back on etc and the lights were no longer on and I drove home but if this keeps happening then what should I do?
Old Jul 22, 2017 | 04:10 PM
number9's Avatar
First thing to check is your battery voltage and best to do after sitting overnight prior to 1st start. Voltage should be about 12.7 vdc. Low system voltage can cause the limp issue.
My S&M wouldn't flash and D2 go limp until I went into reverse then back to drive. Started happening occasionally the progressed to every time. Ended up replacing the x,y,z switch with a good used one.
Old Jul 22, 2017 | 05:15 PM
Meldav32's Avatar
See now when I was in my friends driveway as saying goodbye etc I had already started it then I put it in drive and then my friend kept talking and so I put it in reverse to go back a little then back to park and that's when I noticed the lights flashing. I've been under the hood since home found out my air filter was pretty nasty so I bought a new one changing it, I did clean the terminals etc and reconnect the battery so I will drive as normal for now and if it keeps happening I will go to the XYZ and where is this XYZ located? Not really sure what it even is lol never heard of it but I also have never owner a Land Rover til march of this year either so I'm learning tons of fun things lol
Old May 6, 2018 | 11:18 PM
Steve Jepson's Avatar
Is it possible that your just low on transmission fluid ?
Old May 7, 2018 | 06:22 AM
Meldav32's Avatar
Is that a possibility? Will your rover act like that being low on transmission fluid? I still haven’t got it corrected and as of right now it won’t even start yet prior to changing my o2 sensors a few wks back it was okay just still expierencing limp mode and hard starts and it shutting off sometimes outta nowhere even while driving
Meldav32's Avatar
Def ready to throw in the towel just doesn’t make sense something new and crazy each wk
Old May 7, 2018 | 06:24 AM
Meldav32's Avatar
Oh btw the codes being thrown are two front o2, p1590 and misfire cylinder 1 came up twice yet has all new plugs and wires and new code p1319
Old May 7, 2018 | 10:56 AM
Originally Posted by Meldav32
Is that a possibility? Will your rover act like that being low on transmission fluid?....
I don't know. However, it seems possible to me since the car does prevent you from starting it when other conditions that could cause serious damage are present. Perhaps someone who knows can tell us if low transmission fluid/oil could generate the M and/or S lights.
Old Feb 23, 2022 | 06:53 PM
Theresonly1santi@gmail.com's Avatar
Mine had done the whole S M limp mode and the D on the shifter did that too before hand and it was because I put the shifter in D way to fast so try turning it off… cranking it then slowly putting it in D idk though happened to me before but like you said new problem each week and I’m on my new week full of problems lol
NinjaPlease!
Jul 31, 2019 09:03 AM
cedward
Jan 3, 2011 04:39 PM
Rickey_240
Apr 2, 2010 05:33 PM
vanhorn2dallas
Mar 15, 2010 11:29 PM
xb70valkarye
Feb 2, 2010 10:13 PM
