Machine shop took this bracket off my head; where does it go?
Old May 26, 2011 | 04:22 PM
bcolins's Avatar
Default Machine shop took this bracket off my head; where does it go?
Edit: Problem solved. No longer need assist on this.
I picked my 2001 D2 heads up from re-surfacing and the guy pointed to the bracket pictured and said......".not sure where that was on the head. I took it off to resurface."
I know it was on the back of the left or driver's side head and I think some wiring was held by it,....but not certain. Can someone tell me Where and How this goes on the head and what it is securing (wiring, multipin connector, etc)
BC in Cedar Park,
Attached Thumbnails Machine shop took this bracket off my head;  where does it go?-img_2463.jpg
Old May 26, 2011 | 04:57 PM
jafir's Avatar
hmm.... is that the one that holds the crank position sensor connector? If so, it's on the back somewhere.... I'll go look and see if I can find it on one of mine.
Old May 26, 2011 | 05:49 PM
DarylJ's Avatar
I believe you are correct. It should fit on the driver's side head at the rear on the lowest bolt. The engine harness connector for the ckps should slide into that bracket, with the ckps plug on the free side.
Edit: Yep, it is.
It goes like that (I'm standing behind the motor).
Old May 27, 2011 | 07:42 AM
bcolins's Avatar
Edit: Yep, it is.
Cant tell from your pic whats going on there.....but I got it figured out. Thanks for the effort.
Old May 27, 2011 | 03:40 PM
DarylJ's Avatar
Glad you got it. Yeah, that was a really crappy cell phone pic in a dark pole barn.
d2rover
Engine & Internal
Mar 15, 2016 12:28 AM
ImQuattro
Apr 3, 2014 09:17 PM
steveo2000
Dec 18, 2012 11:06 AM
Bundu
Jul 8, 2010 04:45 PM
