Machining spec for milling heads?
Old Dec 17, 2009 | 09:32 AM
meltdowndave's Avatar
Default Machining spec for milling heads?
Taking the heads to a local garage to be checked and milled if needed.
Anyone know what the max is to shave off?
They look flat to me, but what do I know?
Old Dec 17, 2009 | 10:21 AM
XCELLER8's Avatar
Well, I'm far from an authority here but when I took mine in to have them gone through I was told that I had one that was going to need to have .028" shaved to get it "flat" again and that that was too far beyond spec. I ended up buying a used set and had them re-done instead.....and the machine shop only had to remove .004" just to clean them up
Old Dec 17, 2009 | 10:27 AM
lipadj46's Avatar
The specs are in the Rave CD under the topic Cylinder Head - Overhaul:
5. Check cylinder head height at each end of
head. Renew a head which is outside limits.
a 22.94 mm (0.903 in) - New
b 62.56 mm (2.463 in) - New
6. Cylinder head can be refaced to 0.50 mm (0.02
in) max. below head height.
Old Dec 17, 2009 | 10:32 AM
I never check that section of the RAVE manual.
Doh.
Thanks!
Old Dec 17, 2009 | 10:57 AM
lipadj46's Avatar
I think they are in the head gasket repair section too
austinlandroverbill
May 9, 2015 08:43 AM
gbob
Apr 10, 2014 12:40 PM
wastedincome
Oct 24, 2012 03:10 PM
JBEGIN
Jun 27, 2009 12:38 PM
