MAF dies every time it rains
Old Oct 12, 2009 | 10:00 AM
Aaron1976's Avatar
Talking MAF dies every time it rains
I have a 2001 Disco II SE7 that I love although it has been a one way relationship. I feel let down at times and I give the car lots of attention.
I have been through 5 MAF's in the last year. I have a paper air filter no oiled filters in my Disco. every time it rains the dang MAF goes out.
Earlier this year it was raining and I hit a puddle on the road. As soon as I went through the puddle the check engine light came on. I hooked up the computer and it said low voltage MAF. I replaced it and BAM! good to go.
I had my windshield replaced and I had them do a water test as the last one they put in leaked and got into my ventilation system. I got the car back and the check engine light was one and it was running very poorly. Again it was the MAF. I replaced it and no more problems.
Just last week I drove it in the rain again and the check engine light is on. It is the MAF again.
What is going on? all my intake duct work is hooked up properly and I can not figure this one out. I thought someone out there should have had this experience at some time.
Aaron
Old Oct 12, 2009 | 10:14 AM
lipadj46's Avatar
Never had this happen, never heard of it either. Where are you getting these MAFs from? Are they the real deal OEM? Also is there any obvious signs of water on your filter or in the filter housing?
Who's MAF's are you using, does it come in a Rover box or is it aftermarket?
Have you had any moisture on your paper air filter?
I hope you have had those other MAF's replaced under warranty.
Old Oct 12, 2009 | 12:13 PM
Do you still have the gasket that seals the top of the filter box to the bottom of the filter box?
Water will not get past the air filter unless you drown it or the filter is not seated correctly or the gasket to the two half of the filter box is missing.
Old Oct 15, 2009 | 10:14 PM
Aaron1976's Avatar
The MAFs I have been using. I have gone through 2 Bosch, 1 from an online supplier and 1 from Napa auto whick is still good it seems and only $67. I was sick of paying for the bosch but I know they are good units. I just wanted to find out what is going on so I went to cheap road for now.
All my seals and or gaskets are still in place and in good shape.
I have some new info on the possible cause of the probem. I just replaced the battery. It died but I wonder if the battery could have caused some of this? The rover has been starting on the slow side for a while. Wondering if the battery gets low enough, may damage the MAF?
In the past I have cleared the codes at least twice just to make sure. I also look for an signs of a bad MAF. Things like hard or iratic shifting, poor idle, lack of power, and worse fuel economy.
This time I after I replaced the battery I cleared the codes and no probems.
I don't know if this is all intertwined but it seems to be in my view.
Anyone else have any insite?
Thanks,
Aaron
Old Oct 16, 2009 | 10:14 AM
There is your answer, Napa MAF's do not work on our trucks, I have seen a bunch of them go south right out of the box. And a $67 MAF on E-Bay is worth what it cost you to ship it.
If you want this problem to stop, call Tony at the LRRF and order a factory Maf that will last, 650-365-4145.
Old Oct 18, 2009 | 04:04 PM
Aaron1976's Avatar
If you had read my post more carefully you would find that my Napa MAF is still going strong. I replaced the battery in the car as it finally died and I cleared the codes, no MAF codes now. I just drove it 240 miles with no problems.
I know that the stock MAFs are good units but do you think Land Rover makes them? They are contracted out and made by Lucas or Bosch or who ever.
I am not a believer that the stock units are the only ones that any good. I don't believe something just because someone said it. Bosch has a good record but all the components used to make them all come from China any more so what really is the difference. I am happy with my Napa unit and it comes with warranty so I feel better about that then $300 or more from Land Rover.
I hope for my sake I am right. I know you are buying a qaulity product from Land Rover. I just can't make myself spend the money. Maybe I can't be cheap and be a Land Rover owner. I hope I can, I can't afford to pay dealer costs.
Thanks for the post, I enjoy a good debate.
Aaron
Old Oct 18, 2009 | 05:20 PM
Yes, I did miss read your post.
That being said, there have been a number of Napa MAF's fail, even my own local Napa store is aware of it, but being privately owned, they haven't been able to get the point across to the company.
Old Oct 18, 2009 | 05:41 PM
Aaron
Yes you can "Disco on a Budget", I do it all the time, over 30k in 2.5 yrs and not a single break down.
Old Oct 18, 2009 | 05:55 PM
Aaron1976's Avatar
Hopefully this MAF does hold up for a while. I have a leaky air spring when there is enough weight on the rear and a driveline vibration to fix. O and also the three amigo lights are on for a bad wheel speed sensor.
Seems like all this has happened all at once. I need to catch up with repairs.
I bought new u-joints and the cv gimbal kit. I think I will have a driveline shop do the work though. I have replaced lots of u-jounts but I want the vibration to be gone and I am willing to pay for that service.
The air springs are really easy to replace. Mine leaks when it is weighted down and the bad portion of the air spring curves under and flexes where the hole or bad spot is. I have checked all my supply lines for leaks and I did find the leak in the air spring.
I love the Rover but I couldn't take it to the shop all the time. I fix what I know I can do myself and find the money to do the rest. It does pay to do some research for proper parts though. The ignition system needs certain spark plugs and wires.
My old 1986 Saab 900 has been a great car, I wish Rover was the same. I can't kill the Saab. I have been trying to kill it. I would like to upgrade but as long as it has oil and coolant it just keeps on running and running. Rovers engines and trannys go for ever. So I think I will keep it till it is well dead and put some money in the bank. I can go anywere it that rig. And it is fun to drive. I never worry about bad weather in the winter with that thing.
grigri
May 7, 2013 09:55 PM
MoNtErover
Jun 1, 2010 07:42 AM
IDAHO
Dec 18, 2009 10:20 PM
co556guy
Jun 30, 2009 04:22 PM
Princess
May 27, 2009 04:09 PM
