MAF Q's
Yes !!
on
Assuming the fuse for the power to the MAF is good, your problem is the aftermarket MAF's, even the generic Bosch MAF will rarely work on our D2's unless it has the exact same part number.
Take your's back and order a good one.
By the way, the factory paper filter so sooooo many time better the the after market ones for only a couple dollars more.
A D1 MAF is more robust than a D2. It is more capable of handling the K&N, but you really don't get any more performace value out of it. You also mentioned not oiling it? Never a good idea. That is how it traps dirt. Over-oiling is how they hurt MAFs. The oil comes off and burns the sensor wire.
I would still suggest running a paper filter.
