Magnaflow exhaust kits - worth it or not?
Old Feb 27, 2014 | 02:59 PM
Yoops Racing's Avatar
Default Magnaflow exhaust kits - worth it or not?
Are these kits any good for D2s? They advertise increased hp and torque. Thought it may be nice on a Cannibalized V8 motor with a cam. Just curious if there is positive or negative feedback from you all.
thanks
David
Old Feb 27, 2014 | 03:23 PM
ZGPhoto's Avatar
If they do have an increase, it is extremely minimal. You'll gain the most with a larger Y pipe if at all.
Old Feb 27, 2014 | 03:29 PM
Dan7's Avatar
+5 hp...not worth the money (>$100/hp!) unless you need to replace your exhaust anyway...then maybe it's worth the cost. It has a sweet sound though!
Old Feb 27, 2014 | 03:56 PM
that's my initial thought on this as well $589.00 or there about for not so much
Old Feb 28, 2014 | 07:43 AM
ralphobell's Avatar
I replaced the Ypipe with the Magnaflow. I was very satisfied with it. Lost the prop shaft and the pipe took a beating but held up very well. I will be replacing the catback with Magnaflow when it is time.
Old Feb 28, 2014 | 08:15 AM
grandkodiak's Avatar
Ditch the SAI, throw on some longtubes, hiflow cats and run rear wide open with some o2 sims... MAYBE youll see some decent horsepower, you might be able to pass an 18 wheeler on an uphill finally
Old Feb 28, 2014 | 09:00 AM
ems12's Avatar
If you do install a Magnaflow catback make sure you get the magnaflow muffler resonator put on as well, or you can forget about having a conversation with the person next to you.
The drone at 50 mph and 1700 rpm will drive you crazy! The drone at 70 mph will make you certifiable.
I maybe just my imagination but I do have a bit more pick up now then I did with the old factory exhaust and it sounds SWEET!
Old Feb 28, 2014 | 09:11 AM
Racer X's Avatar
I just put a Borla system on mine. Personally I love the sound, and regardless of which system you install, you're going to have some drone regardless.
That said, I love the sound!
Colorado David
Mar 28, 2015 11:14 PM
AtlanticBritish
Member Group And Special Buys
Sep 23, 2011 09:18 AM
AtlanticBritish
Mar 1, 2011 12:35 PM
cslbill
Nov 19, 2009 03:45 PM
gmag211
Headers, Intake, & Exhaust
Feb 16, 2009 03:22 PM
