Is Magnaflow worth the extra money
Old Mar 28, 2015 | 12:17 AM
Colorado David's Avatar
Default Is Magnaflow worth the extra money
I know I need to replace my muffler. I haven't looked close enough to see if I need to replace from the cats to the back. If I do have to replace it all from the cats back, is the Magnaflow worth it? standard Atlantic British kit is $269 and the Magnaflow kit is $608. If you have an opinion one way or the other, chime in please. Thanks in advance for you help.
Old Mar 28, 2015 | 01:36 AM
Dan7's Avatar
It will net maybe +5hp and make a neater sound (subjective). IMO, unless your cats are on the verge of needing to be replaced as well, probably not worth the extra coin.
Old Mar 28, 2015 | 11:02 AM
cybercop's Avatar
That is just for the Cat back!
I personally don't think the Magnaflow is worth it unless you are replacing everything. Then you MAY get that +5hp gain. Some say that the hi flow systems won't be worth it unless you also open up the exhaust ports.
I replaced my Y pipe/cats with Magnaflow and really didn't notice much at all. But I did get rid of the annoying rattle coming from my bad cats.
Old Mar 28, 2015 | 12:34 PM
The other thing to consider is that iirc the magnaflow system is stainless.
That being said I'm pretty sure the exhuast is original on my 00 DII and doing fine, so longevity might not be that much improved lol
Old Mar 28, 2015 | 12:51 PM
cybercop's Avatar
Great point, but how much would that be a consideration in Arkansas? Not much salty road conditions there.
Old Mar 28, 2015 | 01:07 PM
Madlands's Avatar
I have a 99 that has spent its life in Arkansas and after spending time under it yesterday, I believe the stainless steel would be overkill. Rust is the last issue I've ever had with a vehicle here.
Old Mar 28, 2015 | 01:32 PM
Alex_M's Avatar
Personally, I'd just take it to an exhaust shop and have them weld in whatever muffler you want and replace the pipe if needed. It will still come out about the same as OEM. Same deal with the cats, just buy a couple Magnaflow universals.
Old Mar 28, 2015 | 01:58 PM
OverRover's Avatar
If you go with a "Standard" exhaust kit from ANY Rover parts supplier, have them put eyes-on. If the parts are BOSAL (which most standard kits are) just burn your money. The welds are scrap, the flanges are off-center, and the internals rattle like crazy. I wouldn't put a Bosal exhaust on a lawnmower.
Old Mar 28, 2015 | 04:01 PM
wynhd's Avatar
I have a magnaflow in place of my stock muffler and had the resonator removed, it's a little more aggressive sounding. $100 installed, same as buying a no name muffler, this is also stainless and has a lifetime warranty.
Old Mar 28, 2015 | 05:38 PM
drowssap's Avatar
Exhaust shop $225 no rear muffler delete.
