Magnecor spark plug wires.
Old May 31, 2008 | 02:29 AM
OlDood's Avatar
Default Magnecor spark plug wires.
I have a '99 Disco II (107,600miles/4.0 V8) that has been giving me bad dreams since I purchased it (July '07). I've done at least 2 threads: "Bad Gas" and "Driver's taillight problems": both of which remain unsolved.
Anyhow, I have been unable to locatewhich set of Magnecor wires are made for my vehicle. Can someone please help w/some specific model or part numbers. Aslo, my Little Rock tech suggested that I pass on the Rave CDrecommended Champion plugs and go with Bosch 4202 plugs. They seem to be getting phased out and the suggested replacementsare 4002. I have these now (what gap? .032"?) but want to wait to replace wires at the same time. I am a zillion miles from any big city (Memphis and Little Rock are the closest and they are both 140+miles out) and don't know where to find the wires. The Magnecor site didn't show me a Land Rover installation although it's 3am and I could be just not seeing the info I need.
Thanks
Kevin
CV, AR
Old May 31, 2008 | 02:38 AM
Disco2Guy's Avatar
Default RE: Magnecor spark plug wires.
Call Cerrone's and ask for Tony.
Mon-Fri 8am-5pm PT
1-800-736-7992
Old May 31, 2008 | 08:55 AM
Are you going to install the wires yourself, it is difficult but will save you over $400 in labor.
As for the plugs, buy a set of Bosch Platium Plus 4's, you will have goood luck with them.
Old May 31, 2008 | 08:58 AM
www.atlanticbritish.com, www.roverconnection.com.
As for plugs, I use Denso Iridium plugs, others like the NGK G-Power and others like the Bosch Fusion.
Old May 31, 2008 | 02:04 PM
gtagg's Avatar
you could try Apexperformance.net 8mm cost around 84.00 bucks. bosch 4is a good choice.
gTAGG
Old May 31, 2008 | 02:11 PM
Yes, you could try an unproven set of wires on your Disco, but why go thru that twice when and if they don't hold up.
Old May 31, 2008 | 02:14 PM
gtagg's Avatar
opps' didI forget to mention these are Magnecor 8mm wires.
Mike, your right. I went that way once with NKG wires, biggest mistake I ever made.
gTAGG
Paul Grant
Dec 13, 2011 02:26 PM
cegibbs3
Jun 12, 2009 08:16 PM
Aquaholic
Sep 11, 2008 09:14 AM
DuplinDisco
Feb 15, 2008 08:24 PM
kfordric
May 30, 2005 11:29 PM
