Main & Rod Bearings plus Timing Chain
Ok guys, I'm chasing a knock in the lower end. After taking the oil pan out I've ordered the following to be delivered next week from rovers north:
1 PIN DOOR CHECK ARM P38A, DII, QTY 2(TO GET RID OF THE DOOR CLICK!)
2 MAIN BEARING SET ROVER V8 STD. PLM050
3 ROD BEARINGS V-8 STD PLE565
4 OIL SEAL FRONT CRANKSHAFT 2.25 & V8 PLM042
5 GASKET FRONT COVER V8 4.0 & 4.6 PLM036
6 GASKET WATER PUMP V-8 4.0 & 4.6 PLC053
7 SERPENTINE BELT A/C DII W/O ACE 2342MM
8 GASKET OIL STRAINER-BLOCK V-8 3.5/3.9/4.
9 TIMING CHAIN V-8 3.5/3.9/4.0/4.2L
I know I don't need to remove the water pump from the front housing but I will while I'm in there. The serpentine belt will be my back up as I already have a new one in there as well as new tensioner, both idler pulleys are new, and all cooling hoses/tstat are new. What am I missing from this list if anything? Water pumps aren't to expensive, should I just put a new one in? Viscous Unit maybe? Any other parts prone to failure I should replace while I'm in there? Thanks!
Buzz, Mike, I ordered the oil pump but I have a question. In that write on the bearings one user chimed in and seemed pretty upset that RoverMasterTech didn't regrind the bearings? Is this anything I need to know?
