Major oil and steering fluid leak help.
Old Mar 30, 2016 | 04:00 PM
LR03NJ's Avatar
Default Major oil and steering fluid leak help.
I have been loosing a lot of steering fluid and oil as well but not sure yet if its transmission oil or motor oil. I can't figure out why the leak is all the way in front near beside the radiator. I checked the steering pump hoses an tubes but can't find a leak. I have a transmission oil cooler (i just found out) but its tucked between the radiators. Here are some pictures so I can point it out. Need help
The left is the front where the radiator is located. Tubes are coming from the bottom of the radiator which I can't see. I tried cleaning them with rug so I can visually see where the leak is coming but can't tell where still. The upper tube with plastic is wet but can't tell since its part plastic and metal. I think its going towards the transmission.
All these parts are wet with oil or steering fluid, I'm guessing. Top of picture is towards the radiator.
This is also somewhere together with the pictures but I can't remember where but wet with oil.
Front driver side when the grill removed. Lower right was all wet with oil.
Left - Engine. The tubes are going towards transmission. No leak around here except that screwed up guy from the oil change who screw the plug incorrectly and leaking from the plug itself. BTW, can that be rethreaded if damaged?
Old Mar 30, 2016 | 05:47 PM
jamieb's Avatar
Start from the steering reservoir, is it low? Feel underneath for a hose leak and work your way down. May have to degrease from top down and look.
Old Mar 30, 2016 | 08:58 PM
mollusc's Avatar
You should be able to eliminate it as transmission fluid by the smell. That would leave engine oil or steering fluid as possibilities. Since you're seeing fluid right up at the radiator I'd lean towards a leak related to the oil cooler, since I think the steering hoses are generally lower down and further back than is shown in your pictures. Steering hoses only go from the pump to the steering box and back to the reservoir.
Lawson Builder
Apr 22, 2014 09:06 PM
wreckdiver1321
Nov 15, 2012 07:59 PM
tulsa
Nov 7, 2010 08:35 AM
Spencerfitch
Jul 14, 2010 06:03 PM
LRScott
Mar 4, 2009 08:39 AM
