Manafoild Gaskit/Valley pan Blown out ??????
Thank you!!!!!!!! My engine guy has owned his own shop for fifty years so hopefully he knows what to do. Well, he knows a lot more than I do, clearly. Thanks, Dro!
Hijack over. Resume thread. Apologies to all.
To the OP of this thread.
The only thing that can cause the intake pan gasket to blow uo or balloon, is too much crankcase pressure. Your crankcase ventilation uses the positive vacuum from the plenum to the passenger side valve cover and pulls thru the oil separator. The Drivers side has a tube going to the intake before the throttle valve, which is a lower vacuum(especially when throttle is closed).
So either, you have massive blow by from one or more pistons, or your oil separator is clogged, or hoses are not hooked up correctly. Although very unlikely, the only other culprit could be head gasket leak or blown out on intake side right into the valley.
It is but ... Here is a copy and past from above:
I did install a 2ND oil separator in the rocker cover: drivers or LH side. ops..... My 97 had two, maybe i should not have done that ? When I removed it, it was submerged in oil..... but the other side was check and I could blow in it fine.
I just seemed like there was alot of oil in that line before the overhaul, that's why I added one. I removed it, but do not want to just hope that was the issue and have the Manifold gasket to blow out again. Should I just leave the oil cap loss ??? LOL Click the image to open in full size.
Shot in the dark here, are all the return holes in your head clear? Reason I ask, if the pressure in crankcase cannot reach the valve covers, there is no way to remove the pressure, via the Crankcase ventilation route. Also could explain why so much oil is remaining in the valve cover and being pulled into the PVC lines.
Edit: This is probably not applicable, because of all the push rod holes would allow pressure to get to valve covers.
-I remember reading about this same issue a while back. The other person said he could hear a sound like a can being crushed and expanded while the motor was running.
-I believe the problem was caused by user error... Piston was installed incorrectly causing crank case pressure.
-You can read up on it here: https://landroverforums.com/forum/di...n-sound-65926/
I asked the forum about it when I did the overhaul but no suggestions. However It pops every 30 -40secs. The manifold gasket is not moving that much. I may have herd a noise while driving around from the front that was different now that I recall it.
The popping from the tail pipe I was told might be because the tappets need adjusting on the rocker arm. I know there's a guide for that. The thought was that every thing was cleaned and re surfaced; such as the valves and seats, there might be some adjusting to do. Also, I had ordered new injectors to replace the the current ones because 4-5 of them have one jet spaying incorrectly causing it to form a drip. I knew that when I put it back together that I wanted to replace them soon not sure of the outcome if any so far.
I made a jig to flush them but didn't have it set up to back feed them, now the jig is complete as I will use it just to test the new ones real fast before they get installed.
They came out super clean, I made videos and pictures of this whole process but have not posted them because the project is still in the drive way.
Thanks to you all, I will pull the the oil pan off and check my work on the pistons just in-case. Pin in the
, but I will check. I had a guy there with me installing them and checking the correct position. He has his ASE cert; works with me a raytheon. So you would think we could do this LOLKeep you updated soon as I pull the pan.
Too many changes at once.
Never change the OEM configuration.
Keep the engine spec.
Then if / when the rebuilt engine starts and runs for a few weeks OK,
then make a change to something.
If the change fails - back out the change.
View the engine as one component - keep it OEM until proven.
Then the rest of the engine bay are different components.
In testing circles the engine is a "black box".
The rest of the components to the engine are really "interfaces" of
air, gas, electricity, and yes vacuum (negative pressure) and I suppose positive pressure too.
If I was rebuilding an engine - I would keep it spec.
I rebuilt an MG once. I put in a new crank.
And just for grins, I put in a taller camshaft.
BIG mistake.
Car idled like crap.
I got what I deserved.
I would keep the engine spec.
BIG mistake.
