Manual Sunroof Crank
Well everyone is wrong today.
There is one for each roof, look up at the front switch, you'll see a square access button, remove it and insert an allen wrench. There is also one for the rear roof farther back.
ROW (rest of world) DII's were available with a manually operated sunroof. US spec were only available with electric.
If you have electric sunroofs, then you won't have a hand crank. However, it is possible to operate them with an allen wrench as Mike stated.
PERFECT THREAD! The rear sunroof on my new to me Disco 2 is leaking like crazy. I removed the small rectangular access panel next to the rear switches.
Where I would think there should be an allen screw is only a pin of some sort. Def. not meant for manual turning. Anyone tell me IF there is rear allen manual sunroof closing capability for a 2001 Disco 2?
Other questions,
Does the ECM operate BOTH sunroofs? If so where is it located and can it be accessed without removing headliner?
Can REAR sunroof motor be access/serviced without removing headliner?
MANY MANY TX!
Other questions,
MANY MANY TX!
