Manual Sunroof Crank
Old Aug 29, 2010 | 12:08 PM
khandrh's Avatar
Default Manual Sunroof Crank
Does anyone know where the manual sunroof crank is located. Thanks
Old Aug 29, 2010 | 12:18 PM
lipadj46's Avatar
to the left of the eject button
Old Aug 29, 2010 | 12:19 PM
bosshogt's Avatar
Its only power. The two button above the rear view mirror. Otherwise the motor is fried or off track. Or your sun roof ecm of fried.
Old Aug 29, 2010 | 12:27 PM
khandrh's Avatar
I was looking thru the RAVE CD and it showed pictures of manual crank.
Old Aug 29, 2010 | 02:26 PM
Well everyone is wrong today.
There is one for each roof, look up at the front switch, you'll see a square access button, remove it and insert an allen wrench. There is also one for the rear roof farther back.
Old Aug 29, 2010 | 05:56 PM
antichrist's Avatar
ROW (rest of world) DII's were available with a manually operated sunroof. US spec were only available with electric.
If you have electric sunroofs, then you won't have a hand crank. However, it is possible to operate them with an allen wrench as Mike stated.
Old Aug 29, 2010 | 08:37 PM
khandrh's Avatar
Thanks everyone.
Old Aug 30, 2010 | 12:31 AM
bosshogt's Avatar
Ah I like when I learn a new simple feature my Rover has. I added a picture. The sunroof takes a 4mm Allen wrench. It goes up and down easy with he manual wrench.
Old May 16, 2011 | 09:29 AM
gman1001's Avatar
5th Gear
Default Rear sunroof allen access?
PERFECT THREAD! The rear sunroof on my new to me Disco 2 is leaking like crazy. I removed the small rectangular access panel next to the rear switches.
Where I would think there should be an allen screw is only a pin of some sort. Def. not meant for manual turning. Anyone tell me IF there is rear allen manual sunroof closing capability for a 2001 Disco 2?
Other questions,
Does the ECM operate BOTH sunroofs? If so where is it located and can it be accessed without removing headliner?
Can REAR sunroof motor be access/serviced without removing headliner?
MANY MANY TX!
Old May 16, 2011 | 10:13 AM
gman1001's Avatar
5th Gear
Update, I just found the RAVE manual with answered every question except the Manual crank thing.
Ideally I only want to cinch down the glass to the gasket and if I can do this, I'll disable the darn sunroof.
