Manual Sunroof Crank
I'm guessing that used parts from the UK would be the way to go. Much cheaper when you can find them on ebay.co.uk.
BTR8243 MANUAL SUNROOF HANDLE | Discovery 1 1989-1998: Body/Fittings | shop | www.lrseries.com | L. R. Series
BTR8242 MANUAL SUNROOF GEARBOX ASSY | shop | www.lrseries.com | L. R. Series
@Carlos Man yup works just fine, I use a torx screwdriver T25 to open and close mine. However if the motor is completely seized this will not work. In my case I just removed the motor portion and put the gear section back, works fine.
Edit> 100% it fails in the open position and starts to rain within seconds. Or at least that's my luck.
-Greg
It’s a new project new motors are on the list Lol
