Manual Way To Open Rear Sunroof?
Old Dec 29, 2019 | 11:35 AM
cvhyatt's Avatar
Default Manual Way To Open Rear Sunroof?
Pulled my headliner today looking for leaks. It's clear to me I have a problem with the rear sunroof seals and drain tubes. Problem is that the rear sunroof motor appears in operable. Is there a way I can manually open this sunroof so I can properly seal it?
Old Dec 29, 2019 | 11:40 AM
Best4x4's Avatar
Pop trim piece out (small plug) then insert an allen/torx bit & rotate it. The sunroof will open.
Old Dec 29, 2019 | 12:10 PM
cvhyatt's Avatar
Thanks @Best4x4 As I recall there is a technical bulletin for the sunroof remediation but the links to it are dead. Do you happen to have a link?
Disco2001
Nov 10, 2013 04:42 PM
Gerard
Feb 21, 2011 02:03 PM
BigRed98
Jun 21, 2010 12:30 AM
Hedleyj
Jan 19, 2010 03:24 PM
