manually locking the doors
Old Apr 24, 2023 | 07:06 PM
mackendw's Avatar
Default manually locking the doors
I'm putting the disco to bed for a while. Took the battery out, added fuel stabilizer to the gas tank. Question on the locks. If I manually lock the doors,
will I have any issues opening the doors to pop the hood when I return to get it back up and running?
Old Apr 24, 2023 | 07:28 PM
ahab's Avatar
As long as the driver's door lock physically locks and unlocks with the key then you will be able to get the door open to pull the hood release.
I'll edit this for a little clarity:
When you "wake" the truck back up, my advice would be to pull the hood release and open the hood, then relock the drivers door with the key and put something on the hood switch to simulate the hood being closed before you hook up the battery. Then use the fob to unlock and lock the doors a few times remotely, finally leaving them in the unlocked state, before removing whatever is making the BCU think the hood is closed.
Old Apr 24, 2023 | 07:34 PM
mackendw's Avatar
will do. just verified the key in the drivers door does in fact lock/unlock the door manually with battery out.
vgpacer70
Aug 12, 2017 10:09 PM
CATTIVA73
Mar 17, 2016 01:01 AM
Toran
Jan 15, 2016 10:00 AM
dz5bxm
Jun 8, 2015 04:59 PM
Disco__Stu
Jun 18, 2014 09:36 AM
