Marvel Mystery Oil
I put some in my oil last winter and it quieted the valve train right up. This last oil change I did not put any in, and my valve train is back to it's noisy self. So, it seems to work, but I'm not a huge fan of additives as it can change the viscosity of the oil to be out of the acceptable range. My oil test with Blackstone Labs showed a higher level of wear indication than I would have liked with the Marvel in, therefore I left it out at the last oil change. I don't know if the Marvel had anything to do with it, or if it was just coincidence. We'll see when I get my next oil change results back from the Lab.
i have experimented with it in both the oil and fuel and have only good things to say about it. I have seen it make a noticeable difference in the way a vehicle runs. I consider it a detergent/solvent as opposed to a super lubricant like engine Prolong, of which I have also seen positive proof of its efficacy.
For the record, I've tried a few other oil and fuel additives, and none have had any noticeable effect.
mmo
I put 8oz about 150 miles before my last oil change. I think it helped. I am not sure how it would be a good idea to run it full time. If it were cleaning the engine it would also be breaking down the oil at the same time. Destroying the lubrication properties of the oil
I use sea foam in my gas tank fairly regularly, seems to make a difference. I run 93 octane 90% of the time.
I have heard of people running a quart of transmission fluid in the engine before an oil change as well.
Everyone has their own opinion on things, i think for the most part a fluid will not destroy an engine. Unless for maybe water. Have you seen the video of guys pouring water in their intake to steam clean the engine? That is ballsy.
As for fuel about 2 times a year I drop a can of Seafoam into my fuel tank to clean things up. Some folks claim Berryman is the same stuff and cheaper.
I use MMO two or three times a year, usually with oil changes-- 24oz or so in the oil, and a good 8-16 oz in the fuel. I've used this on all my vehicles since I've known about it, every other oil change, the past 6-8 years.
I have a 1985 Ford F-250 with a big block, and I use MMO in the wintertime to thin out the 15W-40 oil I use (diesel oil used due to solid lifters, much like our Land Rovers.) It definitely helps there.
On the LR, I use 5w-40 in the wintertime, so I can't really tell the difference from when I've used MMO or not.
I can't say with any certainty that MMO has helped on *any* of my vehicles, but I figure it can't hurt. FWIW, I used to do Blackstone oil analysis on my cars, and the MMO didn't affect wear metals more than a couple % below/above what was baseline. In fact, it didn't seem to add (in any appreciable amounts) any element (wear or additive) tested by Blackstone.
