Mass Air Flow Meter on a 2000 Disco II
Old Feb 20, 2006 | 11:57 PM
flyinrover's Avatar
Default Mass Air Flow Meter on a 2000 Disco II
I have a check engine light on so I ran the code and got this:
P0102 OBD-II Trouble Code
Mass Air Flow (MAF) Circuit Low Input
Can this mean anything other that what it implies, that my Mass Air Flow Meter is bad? Anything to do other than replace? Thanks for your help. -Pete
Old Feb 21, 2006 | 12:52 AM
Bait's Avatar
Default RE: Mass Air Flow Meter on a 2000 Disco II
Pete,
Check your air box carefully. The Factory and/or Techs regularly bend the alignment tabs over creating a air flow disturbance which can cause issues.
Old Feb 24, 2006 | 12:04 PM
disco1's Avatar
You can clean the mass air flow sensor, Take it out and spray it out with electrical cleaner, (not choke cleaner) there are 2 wires which may be blackened and once clean they may work again. Hope it helps
bcolins
Mar 8, 2015 12:07 PM
diesel4eva
Jan 12, 2011 11:05 AM
Gavster
Apr 15, 2009 01:44 PM
Gavster
Apr 10, 2009 02:49 PM
akc
Nov 13, 2008 08:24 PM
