Master Cylinder Brake Lines
Old Aug 27, 2013 | 01:06 AM
Madlands's Avatar
Originally Posted by drowssap
mine will need to be changed; at the time I was doing mine they only had 4 hose kits.
Does anyone know when they started adding the other 2 lines and if you can buy them separate anywhere? I ordered mine from RN 2 months ago tops and only got the 4 lines.
If you're having that hard of a time with them I would just wait and have your Indy do them on down the road. Not saying you can't do it. I just don't see any need to break something when you don't have too, you'll feel a difference with just the 4 until then.
Old Aug 27, 2013 | 09:44 AM
jh.'s Avatar
jh.
Originally Posted by ralphobell
Attached image shows the two lines that need changing. Can you get to the end clamps that attach to the metal lines that go to the rear brakes? If so disconnect those then disconnect the hard lines at the top of the ABS pump. Pull the lines up and then attach the SS lines. Drop the hose backdown and attach to ABS Pump, then attach to metal lines for rear brakes.
Yes those are them...and that's genius....thank you. I should have done this when the ABS modulator was out of the vehicle and I was doing the svs fix.
Thanks...I'll give that a whirl this weekend. Suppose that means I'll have to bleed the modulator again too!
Old Aug 27, 2013 | 11:30 AM
ralphobell's Avatar
Brake Flex Hose Connects Between Modulator And Pipe (SHB101350SS Same Fit As Part # SHB101350) - Land Rover hoses from Atlantic British
Old Aug 27, 2013 | 11:31 AM
ralphobell's Avatar
Yes you will need to bleed the entire system again.
Old Aug 27, 2013 | 07:55 PM
jh.'s Avatar
jh.
Thanks!
Old Aug 29, 2013 | 01:40 PM
acamato's Avatar
Here's another source for the two short lines, they are across the pond.
Extreme 4x4 Ltd DISCOVERY 1&2 BRAKE HOSES
Old Sep 13, 2013 | 01:40 PM
acamato's Avatar
I orders the 2 lines form Crown Performance for $45 + shipping. I had to call them to place the order.
They also sell a kit with all 6 lines. They make them to order. You can choose color (9 colors) and specify lift.
Old Sep 13, 2013 | 09:16 PM
willrok13's Avatar
The flex lines are a real B... To find, and to install.
I ended up getting some from AB for around $16 each IIRC.
FWIW: The way I installed them was to remove the hard line from the ABS modulator and drop it down so I could get to the top nut on the flex line. If mine hadn't been leaking I wouldn't have even tried it lol.
Old Sep 14, 2013 | 08:09 AM
acamato's Avatar
Thanks for the tip on the install. I should have said that the crown performance lines are stainless. When they arrive, I will be replacing calipers, pads, rotors and installing ss +2 lines.
LMcInnis
Jun 12, 2012 12:40 PM
colton
Dec 26, 2007 11:33 AM
colton
Dec 10, 2007 12:14 PM
larry99discoI
Aug 22, 2007 02:35 PM
leebuhrul
Feb 26, 2006 03:38 AM
