Max Tire Size and Front Axle Lock
Old Sep 4, 2013 | 07:13 PM
ZGPhoto's Avatar
Originally Posted by post42
If the locking mechanism is malfunctioning, how does one check or repair that? Has anyone ever heard of one of these mechanisms failing? How is that repaired?
There is no locking mechanism. You can choose to buy a locking differential for the vehicle, they range from $500-1100.
Old Sep 4, 2013 | 08:06 PM
Snafu / Disco Fries's Avatar
Max size is 265/60/18. I have run that on both of mine. Zero rubbing. Stock suspensions. One truck was regular with ACE, the other is air suspension, no ace.
Old Sep 4, 2013 | 08:19 PM
caymandrew's Avatar
Is it possible the previous owner installed a tcase with a cdl lock? I can't think of any other reason why his front tires are slipping while turning. That's exactly what mine does when the cdl is locked and I'm on pavement *was just testing it out.
You might want to get under the truck and look on top of the transfer case, top right of the front drive shaft when looking towards the rear of truck, and look for this connection:
If it's there, turn it counter clockwise to disengage the cdl lock.
Old Sep 4, 2013 | 09:24 PM
post42's Avatar
Thanks for the size snafu
Old Sep 4, 2013 | 09:28 PM
post42's Avatar
That threaded piece?
Thanks for the detailed picture.
I'm in Freeport, nice to hear from a fellow Emerald Coaster!
Old Sep 4, 2013 | 10:44 PM
Here are mine. Stock 255/55 on the black, 265/60 on the red. Makes a decent difference and gave a bit of a lift.
Old Sep 4, 2013 | 11:49 PM
ZGPhoto's Avatar
I was just referring to the axles both being unlocked. It is possible he has a CDL installed if someone else did it on his truck.
Old Sep 4, 2013 | 11:56 PM
Magna Defender's Avatar
Those are 2 beautiful vehicles, especially the red w/tinted windows. I'm not sure that I've ever seen that color red on the road. Very nice.
Old Sep 5, 2013 | 01:59 AM
borchera's Avatar
We just bought the same size and X2 for the this quote.
Old Sep 5, 2013 | 04:38 AM
antichrist's Avatar
It's possible the PO had installed a locker in the front. Jack up one front wheel and try to turn it by hand. If you can you don't have a locker in the front and the center diff isn't locked.
That would mean your chirping is coming from something else.
Put the front end on jack stands and turn the wheels fully right and left and check for rubbing on anything.
