Melted 02 Sensor Connector
Old Jun 1, 2022 | 09:33 PM
328Driver's Avatar
I'm at a loss. So after everything I have spliced in a new 02 harness all the way back to the ECU. I have tested the plug and have 12v constant to one pin. The heater wire will switch to 12v. One pin is constant 4.5v. The earth/signal wire starts at 0v but I tested it at the ECU and it goes to 4.5v when the engine is running. It still is showing a flat line on the graph and throwing a p0134; Could the wires being melted together cause an ECU problem? Any help would be greatly appreciated.
Old Jun 2, 2022 | 05:19 AM
brivalen's Avatar
you can easily figure that out by running on continuity check between the two leads. Any $20 multimeter will tell you.
DiscoNewbe
Apr 20, 2022 09:06 AM
RA122125
Sep 14, 2021 09:45 AM
D24.6
Jun 4, 2016 07:54 PM
GURU06
Jan 28, 2013 06:53 PM
Rearden Steel
Jan 4, 2011 11:10 AM
