mess free oil change??
Old Dec 31, 2008 | 11:48 PM
mattrickman's Avatar
Default mess free oil change??
OK.. Having changed the oil today in my 2 Disco's.. I have to ask...
Is there a way to change the oil without making a mess? After many - many oil changes, I still can't seem to do it without making a mess....
Anyone have any tricks?
Old Jan 1, 2009 | 02:12 AM
AK Rover's Avatar
Default RE: mess free oil change??
The only way I found for me to keep from making a mess changing my oil is to have someone else do it.
Old Jan 1, 2009 | 02:55 AM
sloppyjoe's Avatar
yeah,,,
just take your time.
my last and first oil change on the rover i think i got a drop on the concrete.
just go slow and dont rush it and things go smoothly and cleanly
Old Jan 1, 2009 | 05:12 AM
Urban Panzer's Avatar
Or get one of these, mess free 100% everytime
http://shop.difflock.com/discovery-drainplug-p-41.html
Old Jan 1, 2009 | 08:57 AM
I have seen those before sold by Fram. Not sure how I feel about it though.
I just change my oil in the neighbors driveway.
I put down oil only PigMat and just go nice and slow, I have found that if you run the passenger side of the truck up on your ramps the oil drains at a better angle and it puts all the u-joints up high enough for you to grease them all.
Old Jan 1, 2009 | 11:49 AM
AK Rover's Avatar
I had a drain plug similar to the one UP posted in my Dodge diesel. That was one of the best things I ever added to the truck. The one I used was a ball valve style that just required a 1/4 turn to open and drain. It even had a retaining clip to prevent the valve from opening by getting caught on something off road but I never used it since my Dodge sat so high.
This is the one I used and I highly recommend.
http://www.quickoildrainvalve.com/
Old Jan 1, 2009 | 12:30 PM
I am worried about those drain plugs getting hit while off road though...
I think the biggest reason for a mess is that oil splashes out of the catch pan.. maybe I should find a different style (i use a 15 qt from Autozone)
Old Jan 1, 2009 | 12:57 PM
04BluDisco's Avatar
mattrickman, I think you are probably right about the catch basis configuration being the issue.... I have two... one from the zone, one from shucks.
auto zone (rectangular - 16 qt) has a 'dome' in the middle to direct the oil to the drain, but in reality, just spills over the side first. (read - sucks).
The Schucks one is round and all funnels to the center to drain. Works great and doesn't spill a drop. link for the good one
http://www.partsamerica.com/ProductD...egoryCode=3321
Hope this helps.
Old Jan 1, 2009 | 12:58 PM
My oil drain pan is a 8 quart, been using the same one for 15 years.
I have gotten pretty good at figuring out where the stream will hit, then move the pan to account for the slow stream.
I think that one of those quick drain plugs would allow debris to sit in the bottom of the oil pan and not come out with the old oil.
Old Jan 1, 2009 | 01:09 PM
04Blu - Yeah that is the drain pan I use... I guess I need to work on my technique
Spike - Yeah.. I hadn't thought about that....
