Mezierre inline stat housing
Old Feb 8, 2017 | 12:01 AM
Robert Booth's Avatar
Default Mezierre inline stat housing
I was doing some work under the hood this evening and noticed that I have an intermittent weep from the join on the stat housing. Is anyone using a sealant on the housing? Mine is more than hand tight. If I hadn't observed it leak from there, I'd still be at a loss because my coolant level hasn't noticeably altered in 400ish miles.
Old Feb 8, 2017 | 01:24 PM
chubbs878's Avatar
I have plumbing tape on the threads; never an issue.
Old Feb 8, 2017 | 10:14 PM
DailyDrivenTJ's Avatar
Plumbing tape and use some pipe wrench or giant monkey wrench to tighten.
Old Feb 8, 2017 | 10:26 PM
I talked to mezierre, they're convinced that no tape is necessary if torqued to 25ftlbs.
They're sending me a new gasket. I'll pull it all apart and redo at the weekend.
Old Feb 9, 2017 | 09:47 AM
OverRover's Avatar
I had 2 different Meziere stat housings (WN0071) leak on 2 different trucks. Being that the threads are parallel and not tapered pipe (NPT), Teflon tape or paste sealant won't/can't work long run. The problem was the gasket. I tried a Fel-Pro #35278 (it's thicker) and it sealed like a champ. You can get the Fel-Pro or one like it at any NAPA. Good Luck!
Old Feb 9, 2017 | 10:59 AM
chubbs878's Avatar
great info, thanks for sharing
back9sunday
Jul 15, 2016 05:08 PM
cappedup
Apr 26, 2016 09:31 AM
coors
Dec 13, 2015 11:52 AM
toad2
Jul 28, 2010 08:01 AM
Danny Lee 97 Disco
Apr 9, 2010 12:15 PM
