mike i forgot!
Old Mar 25, 2007 | 06:18 PM
suntattoo80's Avatar
Default mike i forgot!
mike i forgot the tire size you said to use on my disco 1 with the lift OME and what was the sight you said for the lift thank's mike Jason
Old Mar 25, 2007 | 06:47 PM
Default RE: mike i forgot!
Jason, I suggested you contact Tony at 1-650-365-4145 for the OME's and i can't remember how big you were hopping to go but I would say stick with the 265/75/16 tires unless you want to loose alot of power and MPG going to a 285/75/16.
Hope this helps,
Mike
Old Mar 25, 2007 | 07:09 PM
i was going 2 inches up and thankyou for the #
Old Mar 25, 2007 | 10:03 PM
On a D1, anything over 3"s will also require drive shafts, front radius adjustment/bars and ABS lines at least, so keep that in mind.
Mike
Newfoundlandrover
May 8, 2007 10:20 AM
j944
Off Topic
Apr 6, 2007 01:01 AM
newBrover
Feb 4, 2007 12:13 PM
05LandRover
Off Topic
Jun 6, 2006 03:37 AM
05LandRover
Off Topic
Oct 28, 2005 05:09 PM
