Mike same problem Help! Anyone!?!?!
Old Jan 18, 2008 | 12:50 PM
mooal5's Avatar
Default Mike same problem Help! Anyone!?!?!
I have a 96 disco that likes to lose power under load. Its as if someone is pinching the fuel line. Dosn't happen all the time but if i am on the highway going up a hill and lay into it a bit she just cuts off fuel. dosn't die just wont respond. It will eventually fight thru it because she is the best. I have put on the ignition wires and plugs you recomended and a new fuel filter. But the same result. It has also been cranking a few more times to turn over when starting. Anymore ideas? Thanks to all!!
Old Jan 18, 2008 | 01:12 PM
FJL's Avatar
FJL
Default RE: Mike same problem Help! Anyone!?!?!
I'm trying to work this out as well. Same symtoms. I've changed two front O2 sensors and will change the rears now. Mike suggested running a can of BG 44k through the gas tank. When I solve the problem (with Mikes help) I'll post. Pls do the same.
Frank
Old Jan 18, 2008 | 01:15 PM
okdiscoguy's Avatar
Test fuel pressure at the rail. At idle and at 2500RPM. Cold and hot.
Does it feel like it might be mis-firing? The early D1's didn't have carbon cutters on the valves, and if you let it carbon up, the exhaust valves can get stuck open...
Might also think about an induction cleaning and a can of 44K as well....
Old Jan 18, 2008 | 01:19 PM
mooal5's Avatar
I will keep you up to date on my progress. Can i pick up this 44k at autozone? I seafoamed about 2 months ago when I begun this process. Im thinking maby a fuel pump relay. Knowen to be a weak link.
Old Jan 18, 2008 | 03:08 PM
Fuel pump relays have been known to act up on Rovers, so possible problem.
As for the B&G, Napa has many of their products.
Old Jan 18, 2008 | 05:54 PM
spoon's Avatar
Check your voltages. Hey Mike, if you had abnormal/weak voltages at key components, wouldn't that be a cause for the fuel-injection to not work properly?
Old Jan 19, 2008 | 08:34 AM
willstevens's Avatar
None of the auto parts places here in Greater Cinci/Northern Ky carry B&G. If you go to the B&G website you can search shops in your area that use them. I just went to one of those shops and they have given me a pretty good deal on the entire line up of products.
Old Jan 19, 2008 | 09:59 AM
ORIGINAL: spoon
Low voltage will effect the ECU causing it to do all sorts of weird stuff.
vandal996
Aug 28, 2010 12:12 PM
jdad49
Jun 8, 2010 09:00 PM
dingurupa
May 22, 2010 10:23 AM
NWDiscoRover2004
Nov 27, 2007 02:44 PM
amnesia622
Jan 5, 2006 08:11 PM
