Mikes 60k Service List Question
Bear with my ignorance please..
FIRST...
You specified Synthetic Power Steering Fluid...
I have yet to see any Pwr Strng Fluid with "Synthetic" on the packaging... can you recomend a brand name??
SECOND...
I have yet to see Lucas "Power Steering Additive" Ive seen a "Lucas Power Steering Stop Leak"
And I am not sure if the is the product you are recomending.... I generally steer away from anything
that claims to stop leaks.. Especially when it doesnt leak now
THIRD....
AT Fluid..
The Rave manual recomends Dexron IID
I have seen many diffrent Dexron but none specifically IID
Dexron IV and some others..
Mobil I had a full Synthetic.. Would that be good???
The Lucas Transmission additive has been Illusive as well.
Thanks in advance..
Pancho..
FIRST...
SECOND...
THIRD....
AT Fluid..
Thanks in advance..
Pancho..
1-DI's use ATF for power steering fluid, so your tranny fluid goes into your power steering.
2-If you need a oil addative then you need a new oil.
I used Valvoline ATF with stop leak when my PS system was leaking.
3-I used Dexron III in mine. 25,000 miles later no problems.
kcferna
Jul 7, 2009 08:33 AM
