Mikes 60k Service List Question
Old Jan 5, 2009 | 07:00 PM
llPANCHOll's Avatar
Default Mikes 60k Service List Question
Bear with my ignorance please..
FIRST...
You specified Synthetic Power Steering Fluid...
I have yet to see any Pwr Strng Fluid with "Synthetic" on the packaging... can you recomend a brand name??
SECOND...
I have yet to see Lucas "Power Steering Additive" Ive seen a "Lucas Power Steering Stop Leak"
And I am not sure if the is the product you are recomending.... I generally steer away from anything
that claims to stop leaks.. Especially when it doesnt leak now
THIRD....
AT Fluid..
The Rave manual recomends Dexron IID
I have seen many diffrent Dexron but none specifically IID
Dexron IV and some others..
Mobil I had a full Synthetic.. Would that be good???
The Lucas Transmission additive has been Illusive as well.
Thanks in advance..
Pancho..
Old Jan 5, 2009 | 07:33 PM
Default RE: Mikes 60k Service List Question
1-DI's use ATF for power steering fluid, so your tranny fluid goes into your power steering.
2-If you need a oil addative then you need a new oil.
I used Valvoline ATF with stop leak when my PS system was leaking.
3-I used Dexron III in mine. 25,000 miles later no problems.
Old Jan 5, 2009 | 07:51 PM
I must add that ATF is backwards compatible.
So Dexron IV will work in a Dexron II system.
Any full syn would be good.
san988
LR4
Oct 31, 2013 09:00 AM
pilsner
Jun 5, 2012 11:24 AM
discotomato
Feb 18, 2010 02:18 AM
kcferna
Jul 7, 2009 08:33 AM
llPANCHOll
Jan 9, 2009 07:05 PM
