Mil Spec
Old Jan 4, 2016 | 09:59 PM
Herb's Avatar
Default Mil Spec
When I first started in Land rovers it was a 1992 Range Rover. Every fluid for it had a mil spec which made it easy to get all the right fluids. I now have a 2004 D02 and there is no reference to mil spec making fluid identification nebulous. Was wondering if
Amazon.com: Mishimoto MMRA-LC-5050F  Liquid Chill Synthetic Performance Radiator Coolant: Automotive Amazon.com: Mishimoto MMRA-LC-5050F Liquid Chill Synthetic Performance Radiator Coolant: Automotive
synthetic antifreeze was viable, but without cross references it is hard to tell. When Mil Spec is available it makes life so much easier. Any links to mil spec?
Old Jan 4, 2016 | 10:11 PM
Alex_M's Avatar
I've never seen the stuff, but considering Mishimoto makes such quality radiators I'd say their coolant is pretty good too. That said, it's pretty expensive. It should work fine, but you can get universal green which is fine and it will last just as long.
All of that said, all the same fluids that you used in your 92 Rangie will work in your disco as long as the Rangie had the V8 engine. It's the same engine that's used in your Disco except the Disco has a longer stroke.
Old Jan 4, 2016 | 10:58 PM
number9's Avatar
Default Syn The New Mil Spec
Fairly pricey stuff with a SOP 2 year change interval they call for but should keep the wondering dogs and cats safe.
Think the full strength
& distilled water would be a bit more economical.
What ever we use getting as much air out as possible is probably the best defense against corrosion and crude.
jokarover
Oct 11, 2014 06:51 PM
wastedincome
Oct 24, 2012 03:10 PM
Smorgan2004
May 28, 2007 06:50 PM
chelo
Mar 14, 2006 05:26 PM
