Milkshake oil, but not lots of coolant missing
Old Mar 31, 2014 | 09:34 PM
Francopacks's Avatar
I found a pressure tester. Here are my results:
5:19PM Start test 1 - level 1/8in low
5:19PM a tad over 15 psi
5:43PM a tad under 15 psi
6:19PM 14 psi
6:45PM 14 psi
7:19PM 14 psi
During the initial test I discovered a leaky hose clamp where the cooling system goes through the firewall to the heater core. I replaced the clamp and am running a secondary test currently. I plan on letting it sit overnight to see what it does.
7:22PM Start test 2 - level 1/2in low
7:22PM 18 psi
7:42PM 17.5 psi
8:22PM 17 psi
9:26PM 17 psi
9:42PM 17 psi
10:01PM 17 psi
10:27PM 17psi
10:43PM 17 psi
Old Mar 31, 2014 | 10:48 PM
I also pulled all the plugs out to see if any of them were wet with coolant during the pressure test. All 8 looked good. Cylinder 8's plug had a slight orange tint, but was dry.
Tomorrow night I'll do a compression test.
Old Apr 1, 2014 | 07:49 AM
The pressure this morning at 7:42AM was 16psi
After taking the pressure tester off the coolant level had stayed the same from start to finish (it's still about 1/2in low from the prior test).
What results would I expect to see if it was the timing cover vs the head gasket vs the block?
Old Apr 1, 2014 | 08:18 AM
drowssap's Avatar
so you still have a small leak somewhere, just for S&Giggles heat the motor up and try it again. See if it hold pressure as well or if the pressure goes up in .
Old Apr 1, 2014 | 08:41 AM
Ok, I will do that when I get home from work tonight.
Old Apr 1, 2014 | 10:15 PM
I started the engine up and ran it for awhile while I had the pressure gauge hooked up. The pressure didn't climb really fast, so I probably don't have exhaust gas leaking into the cooling system. I let the engine heat up for about 30 minutes (coolant got to 207F/208F and stayed there) and it rose to 7psi. I am running the pressure test now on the warm engine and will post the results shortly.
Old Apr 2, 2014 | 11:30 AM
Well, I completed the hot block coolant system pressure test this morning. However, the test is invalid because I didn't have a good seal between the adapter cap and the gauge. I'll have to do it again tonight. below are the results anyhow:
4/1/2014 9:23PM 18psi - Coolant temperature=189 F
9:30PM 15psi
9:35PM 13.5psi - Coolant temperature=165F
9:40PM 12.5psi
9:45PM 12psi
10:28PM 9psi
11:00PM 8psi
4/2/2014 7:45AM 5psi
Old Apr 3, 2014 | 11:22 PM
velija's Avatar
Sorry to hear I didn't really go through the comments but I just recently had milkshake oil
I had the head gaskets replaced only 11 k before that so I figured and hoped plot wasn't a bad gasket
Turned out to be the front cover gasket ( timing chain gasket)
While I was at it I replaced the timing chain sprockets and water pump
Worked out for me I could see where the front cover blew once I had the cover of
Good luck to you sir
Old Apr 3, 2014 | 11:23 PM
velija's Avatar
Also the way I was sure it was the front cover I pulled the oil pan and pressurized the cooling system it was clear the the Coolant was dripping from around the front cover area
Once again good luck
Old Apr 4, 2014 | 10:23 AM
Dane!'s Avatar
That's a good idea. Pulling the pan with the pressure tester.
