Minimum Rotor thickness
Old Jan 2, 2009 | 11:04 AM
Chrisinhouston's Avatar
Default Minimum Rotor thickness
I plan on rotating my tyres (don't you just love British spelling) today and was thinking I would put a micrometer to the rotors and check my pad wear. Does anyone know the minimum thickness for a 2003?
Old Jan 2, 2009 | 11:36 AM
Default RE: Minimum Rotor thickness
One other question... What should I torque the lug nuts to when I rotate the tyres?
Old Jan 2, 2009 | 11:44 AM
The thickness is stamped on the edge of the rotor. Do your brakes shake when doing a hard stop, I don't mean the ABS, just trying to see if they are warped yet.
Atlantic British has a sale on their brake sets, might check them out.
Make sure to do a full 3 pint, DOT 4, brake bleed, use lots of sound deadening spray and torque your wheels to 105#'s.
Mike
Old Jan 2, 2009 | 04:00 PM
Proper lug tourqe is 100 lbsft.
Old Jan 2, 2009 | 05:17 PM
5# one way or the other is not a question.
My manual shows 105, if your show 100, that is fine, just make sure they use the correct socket and a accurate torque wrench.
Old Jan 2, 2009 | 05:45 PM
llPANCHOll's Avatar
I just flushed my brake fluid, and wondered what that film was between the wheel and the hub.. Sound Deadening Spray eh?? Where do I find this stuff, Ive never seen this before.
Old Jan 2, 2009 | 05:56 PM
wesley64's Avatar
speaking of tourqe settings;i had new tires put on in the summer.about a month later i wanted to take off a front wheel for a brake pad inspection.i actually bent the factory lug wrench trying to takethe front wheeloff.finally got it off with long pipe and sore back.a lesson learned about tire shops.alwaysinsist that you want the lugs tourqued to specifications.they always hammer them on with 400ft/lbs.would not have wanted to change this tire on the highway somewhere.
brett
Old Jan 2, 2009 | 07:11 PM
That is why it is wise to keep a 24" breaker bar and a 1 1/16th 6 point socket in your truck at all times.
Old Jan 2, 2009 | 07:22 PM
Urban Panzer's Avatar
Minimum Disc thickness is here on my page,
http://www.discovery2.co.uk/brakes.html
The wheel nut torque is 103 lbs ft or 140 NM in my book / manual. What's this 1 1/16 socket business? [8D], it "should" be 27 mm
Old Jan 2, 2009 | 08:07 PM
ORIGINAL: Urban Panzer
See we live in AMERICA, we use SAE sizes not that metric crap that you guys who drive on the wrong side of the road use.
