Minor engine fire this a.m. - wiring harness
Old Oct 29, 2019 | 03:13 PM
DonRW2007's Avatar
Default Minor engine fire this a.m. - wiring harness
Pulling into work this morning, my truck abruptly shut off. As I coasted into the driveway, smoke started coming out of the engine compartment. Opened hood and saw flames on passenger side near manifold. Grabbed a fire extinguisher from the building and put it out. Looks like wiring harness made contact with exhaust manifold and burned partially through. Car will still start - may just require some minor splicing, but figure I might replace the entire harness.
Any idea how many shop hours to remove/replace?
i can’t recall how the old harness was secured - no idea what caused it to come loose or otherwise contact the manifold. Maybe check your own truck to be on the safe side.
Old Oct 29, 2019 | 03:17 PM
Sixpack577's Avatar
If you can solder, I'de buy some wire and fix it yourself, it'll save you Alot of money vs paying a shop for that.
Old Oct 29, 2019 | 03:45 PM
mollusc's Avatar
pretty sure the harness is normally anchored into those two holes that you can see on the ascending coolant pipe.
Old Oct 29, 2019 | 06:23 PM
Extinct's Avatar
Correct on the anchor points. Probably 6-8 hrs to swap the harness due to a lot of it being under the intake and behind the front accessories.
Old Oct 29, 2019 | 06:39 PM
I had a similar situation, rebuilt the burned section and moved on been good for 7 years
Old Oct 29, 2019 | 06:55 PM
DonRW2007's Avatar
Default Thanks all
Glad it didn’t burn to the ground! I may fix this section or bite the bullet and replace the entire harness as a PM. Thanks again for input.
DRW
Old Oct 29, 2019 | 06:59 PM
DonRW2007's Avatar
Anyone have a picture installed correctly? I don’t think mine were ever mounted correctly. Shame on me - been driving for 8 years on and off...
redwhitekat's Avatar
Wow disco 2 always finding new ways to **** you off. Unbelievable
Old Oct 30, 2019 | 04:02 AM
JUKE179r's Avatar
To keep that exact cable/wire assembly out of the way of the exhaust manifold, I used 2 plastic wire ties to secure it to one of the two holes on the coolant pipe.
Old Oct 30, 2019 | 07:40 AM
wjsj69's Avatar
I hope you insulated all those wires b4 trying to start it! That's a good way to finish the job and/or cause damage to other components if not!
