Minor idle issue.
Old Jun 20, 2008 | 12:00 PM
Phototone's Avatar
Default Minor idle issue.
94 Disco 1, 3.9 v8, 5 sp. standard. 175k miles. I have done all the recommended services to the engine. Seafoam Induction cleaning, replaced IAC valve, new LR original Distributor cap and rotor, new Magnacore 8mm wires, Champion plugs, new Accel performance coil, cleaned throttle body. Checked and replaced all suspect vacuum hoses, new air filter and fuel filter. Truck starts quick and runs smooth and powerful....except for one minor issue.
When doing a hot start, like shopping, and getting back in the truck to go, while the engine is still warm, starts right up, then the idle sometimes drops to zero and the truck stalls. Restart, give it a little gas and it works fine again. (All starts are quick...no long cranking) The truck normally idles at between 750 and 900 rpm. This is a minor inconvenience. If I remember to "gas" it a teeny bit after I start then I can "work around" this issue, but it is still puzzling.
Old Jun 20, 2008 | 12:01 PM
Phototone's Avatar
Default RE: Minor idle issue.
d
Old Jun 20, 2008 | 08:02 PM
I would have to say it is the fuel temp sensor. If it happened when cold it would be different, but it is only hot starts so that is what I would do next.
Old Jun 20, 2008 | 08:12 PM
Phototone's Avatar
Never happens when cold. Where is that fuel temp sensor on a 94 Disco 1??
Old Jun 20, 2008 | 08:16 PM
I belive that it is on the pass side of the engine.
http://www.roverparts.com/TechTips/h...t_problems.cfm
Old Jun 21, 2008 | 06:34 AM
Landzu's Avatar
Fuel temp sensor is on the fuel rail left side, just behind the oil cap in front of the intake.
It will not leak fuel when changed as it doesn't go through on the fuel rail.
It almost looks like a oil pressure switch.
DiscoBenjamin
Jul 10, 2011 02:22 PM
Bob2003Discovery
Dec 9, 2008 04:55 PM
Camdisco24
Nov 22, 2008 08:53 AM
willlane
Jun 20, 2007 10:57 AM
dma3
Apr 2, 2005 02:55 AM
