Misfire #6, need help
Old Feb 14, 2015 | 12:44 PM
Jared9220's Avatar
Default Misfire #6, need help
Deleted
Old Feb 14, 2015 | 01:07 PM
OffroadFrance's Avatar
Hi Jared, long time. A comp test should reveal any issues with #6. Have you checked for sparks on the #6 plug? also is the fuel injector working OK?
Old Feb 14, 2015 | 01:23 PM
Originally Posted by Jared9220
Hey france, Good to see you are still around here helping out. I just went out and checked for spark on #6 and I have none. I checked the other plugs that share the same coil and they have spark. Is it even possible for 1 port on the coil to fail without effecting the other 3?
And I'm thinking the fluid on the #6 plug I thought was oil, is more than likely just fuel that wasn't getting burned from lack of spark.
Hopefully you're on a winner Jared. I'm not sure how many feeds to each coil pack but yes it's possible to have one duff feed on a pack. If you have access to a spare good coil pack swap it and hopefully problem solved. Clean #6 spark plug well and allow to dry out before re-using it.
Old Feb 14, 2015 | 01:44 PM
Just my luck, I think a coil pack may be the one part on this truck that I don't have a spare for. I guess I will have to buy one, but I'm thinking that with 170k it might be time to just buy a new set of coils and be done with it. I haven't even looked up the price yet so my feelings on that might change once I find out how much LR wants for them. I'm off to find a deal
Bummer, it is possible to test coil packs but DANGEROUS as you could end up with very white straight hair at best or even a heat attack at worst. They can give you one hell of a 'bang'
Are the coil packs 1x8 or 2x4 feeds?
Old Feb 14, 2015 | 01:55 PM
Bosch set $135 or All-makes $67? I don't mind spending the extra coin if this is one of those parts that shouldn't be aftermarket. Any thoughts?
All makes are usually reasonable quality (Britparts are crap) but the Bosch should be very good and reliable. I think due to the enormous difference in prices I'd try the All Makes first as they can't be that bad. I looked up coil packs in the UK Ebay and they vary greatly in price from £50 to £150 a pair and some are for one only. It's a difficuly one as the Bosch are twice the price but Bosch is expensive anytime. If it were my money I'd settle for the All Makes with the warranty.
Buy just one if you can and fit to the duff side, #6 cylinder and if you go for a pair keep one in stock for later but I hope you won't need it anytime soon.
Old Feb 14, 2015 | 02:53 PM
ls1morethanyou's Avatar
if you need one to test i can send you one, i need to make some time to put back the rover
Old Feb 14, 2015 | 03:15 PM
Hey Juan good to talk to you again. What's wrong with your truck this time? I might take you up on that offer as it looks like the earliest I can get one shipped here is Monday the 23rd. It might be worth it for me to just cruise on up to you and pick it up in person. I think I can make the round trip in 10hrs. Maybe Ralph or someone in Austin has one I can buy off them. Has Ralph been on here lately?
remember the loosing coolant, turned out to be the intake manifold has hand tight.... so i tore it apart/ had to get heads machined and bought arp studs and the weather went south and work kept me busy so the rover is sitting with heads ready to go.
i just need time to do it and it looks like ill have it soon. though who knows haha
i haven't seen him around, so i dont know. Let me know what you want to do.
Old Feb 14, 2015 | 05:00 PM
Cool deal!
Dino76
Oct 20, 2017 07:57 AM
Gromeo
Jan 24, 2013 03:41 PM
bruter7
Mar 10, 2011 09:19 PM
BIG g
Jun 14, 2010 01:44 PM
tunernewb92
Oct 20, 2009 07:15 PM
