misfire
Old May 7, 2015 | 07:12 PM
Celto 4's Avatar
Default misfire
hi all so ive done a leakdown check on number 1 and number seven the two cylinders that were throwing misfire codes number seven only losing 5% and number 1 about 8-10% and this was done cold....will do the others tomorrow
Old May 8, 2015 | 07:45 AM
Celto 4's Avatar
well 1-3-7 are all at 5% loss number 5 is 18% loss dont really know where to go from here as #1 and # 7 were the misfire cyl this was done cold as well please suggestions?
Old May 8, 2015 | 07:49 AM
Celto 4's Avatar
and that is rings? hissing in the crankcase
Old May 8, 2015 | 07:55 AM
drowssap's Avatar
lets go back you had a misfire codes for #1 & #7, did you do any diagnosis before the leak down test?
Old May 8, 2015 | 09:11 AM
Celto 4's Avatar
hi yes did all the stuff i thought of good spark changed plugs no a/f in the oil and no smoke at the rear end did a compression test and they all showed the same though i have to admit i think they were a bit low as i didnt roll it over enough warm and cold showed about the same has new coils good spark at those cyl plugs were black though and wet after a brief run thanks for your reply
Old May 8, 2015 | 09:18 AM
Celto 4's Avatar
yes codes 301 307 1300 only
Old May 8, 2015 | 09:41 AM
Celto 4's Avatar
check ohm impedance at injectors all 15
Old May 8, 2015 | 09:51 AM
drowssap's Avatar
I see new plugs and a coil? wires?
Old May 8, 2015 | 10:12 AM
Celto 4's Avatar
yes and checked spark at plug very good
Old May 9, 2015 | 09:56 AM
acamato's Avatar
How old are the wires? You said that you checked them and you had spark. If they are old, I would replace them. It could also be a intermittent miss causing the code.
Spark Plug Wires for Discovery and Range Rover
