misfire
hi all so ive done a leakdown check on number 1 and number seven the two cylinders that were throwing misfire codes number seven only losing 5% and number 1 about 8-10% and this was done cold....will do the others tomorrow
hi yes did all the stuff i thought of good spark changed plugs no a/f in the oil and no smoke at the rear end did a compression test and they all showed the same though i have to admit i think they were a bit low as i didnt roll it over enough warm and cold showed about the same has new coils good spark at those cyl plugs were black though and wet after a brief run thanks for your reply
How old are the wires? You said that you checked them and you had spark. If they are old, I would replace them. It could also be a intermittent miss causing the code.
Spark Plug Wires for Discovery and Range Rover
