Misfire, changed wires and plugs... Whats next?
Just bought a 2004 D2, 77K from a Japanese guy that spoke no english. He told me, as best he could, that it needed a new motor, no compression, and misfiring.
No internal tapping or clanking noises, only misfiring. Some oil leaking around valve covor/SAI on Drivers side. Actually still drives OK, has pick up, but rough. Oil is clean as is coolant.
SES is blinking.
Codes its throwing:
P1300
P0303
P0306
P0305
after changing to 8mm STI wires and Bosch platinum 4s.
I have read many threads and I could attack a variety of the possibilities(CPS, O2 sensors, MAF, etc), but does anybody have a sensible checklist in order of importance/economy?
I don't mind spending money on the car, but want to do it wisely.
I did find that there is an exhaust leak on the passenger side at the header/Y pipe junction (missing two bolts). Ordered the bolts and will put them and a new gasket in tomorrow. If this does not magically fix the issue...
What next?
Thank you in advance.
SES is blinking.
Codes its throwing:
P1300
P0303
P0306
P0305
What next?
Coil pack
P1300 catalyst damaging level
P0303 cylinder 3 misfire
P0306 cylinder 6 misfire
P0305 cylinder 5 misfire
5 and 3 are on the same coil, but 6 is not.
Thanks for the quick suggestion.
I've been driving my Disco since 2008 and the only thing that has ever made my SES light blink like the turn indicator was when my Throttle Body Heater Plate was leaking coolant all over the Crank Position Sensor. Not saying you have a leak(I don't know...You might) but what I am saying is that the crank sensor not reading right for any reason, including just failure in general, will cause the SES light to blink and the engine run rough. Check that sensor.
could be
