Misfire Help!!!
Old Jul 11, 2015 | 04:37 PM
cappedup's Avatar
Originally Posted by Hartattak
Just changed the coil pack and I have the same issues and codes p0300 & p0308. When I had the upper intake off the port for cyl 8 had dark black residue in it, the others were clean and dry.
It runs fine up to 2k rpm but then starts missing.
This is so frustrating!
Thanks for any help on how to proceed.
-Hart Bordelon
Hammond, LA
I've just had and solved a misfire in record time. Number 5 wire was touching that y pipe who's function I'm not sure of. It had destroyed the insulation on the plug wire.
I would start cheap and see if your spark is escaping. Run the engine in the dark look for arcing. The benefit is that you know exactly where to look.
Swap the lead and plug to a different position. See if the problem follows the bits.
Old Jul 11, 2015 | 05:04 PM
disc oh no's Avatar
I would take a look at the fuel trims. It sounds like the #8 injector may be sticking open slightly. If it is sticking, the fuel trims on that bank should be in the negative significantly. (significantly is more than 10%) This kind of problem can be tricky to diagnose. Even if you use a scope, you need to pay really close attention to the pintle hump when the injector shuts down.
The only way to really be certain of a problem like this is to do an injector balance test, but not everybody has the equipment to do that kind of thing at home. I think OTC makes a tool for this, if you want to look into it.
Anyway, to sum it up, it looks like you've more than likely got a sticky injector. There are a lot of things that can cause this, so take your time with diagnosis.
Gromeo
Jan 24, 2013 03:41 PM
tommytwotone
Sep 22, 2009 05:45 PM
r2racer
Apr 10, 2009 08:53 PM
rravenn13
Oct 15, 2007 08:06 AM
rravenn13
Oct 13, 2007 11:27 AM
