Misfire question
Old Jul 10, 2016 | 09:30 PM
jamieb's Avatar
Default Misfire question
After I changed the plug wires a couple months ago, I let one touch the exhaust gas recirc pipe and burned a spot in the wire. Managed to get another #5 wire on with only the SAI pipe and hood removed. Ordered a new set of Kingsborne wires. Until then.... Still have a minor misfire but no codes.
Question: why, when sitting at idle is the misfire worse while in drive than if I shift to neutral?
And.....I usually run with lights on in the day. At a stop light I turned lights off and shift to neutral and the misfire is not noticeable. Otherwise, a minor sporadic stumble.
Just curious why changing this affects a misfire?
Old Jul 10, 2016 | 10:00 PM
number9's Avatar
May just be the small additional loads put on engine by alt w/lights and trans in drive. Do AC have a similar effect.
Old Jul 11, 2016 | 10:40 AM
jamieb's Avatar
Yes, slight effect. It just seemed to me plugs fire at a constant rate/voltage and if something was grounding out it would not change with electrical demand on the plug wires. But, conventional wisdom says they are worse under load so I guess the system attempts to draw more power from the ignition
Charlie_V
May 28, 2017 12:18 PM
BamaDisco2
Feb 4, 2016 09:27 PM
slickwilly1976
Jan 7, 2015 10:43 AM
Gromeo
Jan 24, 2013 03:41 PM
MTristan
May 4, 2011 12:05 PM
