misfires
Old Jul 16, 2007 | 09:43 PM
hendoc3's Avatar
Default RE: misfires
So do you think its the catalytic converter or the spark plugs and plug wires or a combination of both? I will be removing the spark plugs tomorrow evening. I dont understand exactly what you mean by "catalyst damaging misfire". Does it mean the misfire cause the damage to the catalytic converter or the catalytic converter is causing the misfire?
Old Jul 16, 2007 | 10:32 PM
okdiscoguy's Avatar
I think it just means the mis fire (backfire) was so bad it caould cause damage to the catalyst. Not sure though...
I don't think your cat is causing anything. I agree with Mike, Magnacor wires and new plugs
Old Jul 17, 2007 | 10:06 AM
hendoc3's Avatar
Any tricks for replacing the plug wires. Just by looking at them yesterday they seemed to be tricky. Just wanted to know before i start working on it this evening.
Old Jul 17, 2007 | 06:21 PM
hendoc3's Avatar
Hey Mike, got plug number 3 out and the center contact is black, sooty, and burnt completely. It looks like the white ceramic part is burnt on one side like an electrical burn. Also, should I use Never-Seez when reinstalling new plugs? The rest of the plugs are black as well but not as bad as number 3. Changed all the plugs and still misfires. Guess plug wires are next.
Old Jul 17, 2007 | 09:50 PM
hendoc3's Avatar
If its not the wires, maybe the coil pack. The number 2 and 3 plug wires are on the same coil pack correct?
Old Jul 18, 2007 | 03:10 PM
hendoc3's Avatar
In case you all were wondering. My case ended up being the coil pack where both cylinders 2 and 3 are located.
damnlows10
Mar 4, 2024 07:53 PM
mattrickman
May 24, 2008 11:37 AM
Jawbox
Oct 10, 2007 09:14 AM
japt29
Jul 19, 2007 09:24 AM
whodey
Mar 6, 2005 01:49 PM
