misfires after coil, plugs and wire replacment
Old 04-02-2010 | 11:20 PM
jrm123180's Avatar
I do have to say that the misfire I did have on cyl 2 is now gone. (this was part of the reason for wire and coil and plug replacement...
Old 04-03-2010 | 11:47 AM
jrm123180's Avatar
I have not checked the compression at all as I just pulled on the the wires of and put an old plug on the end to see if I am getting any spark which I am NOT getting. Like I said, I did put one of the old coils back in and nothing new. I'm wondering if I have a broken wire going to the coil if that is possible?
Old 04-03-2010 | 11:59 AM
greg409's Avatar
Yes, although not likely unless damaged
Did you ever pull the connector off your ECU to see if it's immaculate? (disconnect battery) Have radio code?
Signal to coils is from ECU
luck,greg
Old 04-03-2010 | 10:16 PM
jrm123180's Avatar
Have not done that yet, that is my next step. I did have a mouse problem with this as it was sitting for so long in the woods. pulled a HUGE nest out of my vents fan. (which is near the ECU I believe)
Old 04-03-2010 | 10:22 PM
greg409's Avatar
God, I really don't like cat food, although do they chew thru' copper?
LiL' bastids
luck,greg
Old 04-04-2010 | 12:16 PM
jrm123180's Avatar
ok, I'm pretty sure I figured it all out! On each coil, there are three wires, the middle one on the left coil is pushed in so it is not making a connection to the middle pin! Now all Ihave to do is fix that pin, reassemble the engine and hope that I"m ready to go! (well until I get my new o2 sensors...) I'll Keep you posted as to whether or not this solved my problem.
Old 04-04-2010 | 05:46 PM
greg409's Avatar
I love it when intellect & skill come together & work their magic
luck,greg
Old 04-04-2010 | 08:52 PM
jrm123180's Avatar
absolutly...so glad it's taken care of...now to get the crack in the SAI tube taken care of!
Richie773Rich
05-19-2015 03:03 PM
GiGi La Luz Ramone
08-31-2013 05:46 PM
Ben_S
12-27-2012 09:59 PM
Discosomewhat
09-14-2012 11:38 AM
Gavster
06-17-2009 09:50 AM
