Misfires all on bank 2... 12 fault codes
Old Mar 21, 2014 | 06:06 PM
NCguy's Avatar
Disco Beau,
I feel your pain, In November, I had the heads done, put new gaskets in, new radiator, t stat, air box, MAF, water pump, 8 mm Magnacor wires, the plugs ( I forget which ones everyone here recommended), reservoir tank. new y pipe with new cats and 4 new oxygen sensors. I am getting code 1300, 302,306 and 308, not missing 135, 155, 134 and 154. I just replaced the cam shaft sensor today and still getting random misfires. I NEED HELP?
Old Mar 22, 2014 | 05:43 PM
DiscoBeau's Avatar
Originally Posted by NCguy
Disco Beau,
Sounds like you need an ECU. I'm still having problems, but mine is just more **** going bad. Oh well, all part of the disco fun lifestyle. Lol
Old Mar 23, 2014 | 12:50 PM
NCguy's Avatar
I figured it out, I was an idiot, when I installed the front two 02 Sensors I did not push the connections all the way together until they clicked. Once I did that everything was fine. I could kick myself for such a stupid mistake. But good thing is that I do not need an ECU!!!!
Old Mar 23, 2014 | 12:58 PM
tuercas viejas's Avatar
I trust you have the orange connector O2's up front!
Once running what is your LTFR if you can read it? And after a run cycle and cold soak can you close all the monitors with the scan tool reader you have?
This is way the way you can check your work.
T/V
Old Mar 24, 2014 | 07:50 AM
drowssap's Avatar
clear all your code drive it for 50 miles and see if they come back
robson
Feb 22, 2018 05:42 PM
wediveaxa
Sep 23, 2010 07:12 AM
98roverguy
Sep 28, 2006 09:23 PM
