Misfiring on 1,3,5,7 any ideas
Old Nov 22, 2009 | 09:03 PM
Hennessey's Avatar
4th Gear
Default Misfiring on 1,3,5,7 any ideas
New 03 DII owner with 72K miles. I got a misfire #5 and an O2 error about a week ago. Now I'm getting misfire code on 1,3,5,7, lean fuel and O2 errors. Is this a coil pack issue?
Old Nov 22, 2009 | 09:20 PM
lipadj46's Avatar
That would not be a coil pack I don't think. If it were 1,6,4,7 or 2,3,8,5 then it would be a coil pack.
Old Nov 22, 2009 | 09:25 PM
hilltoppersx's Avatar
bring us all the codes. what type of wires and plugs do you have?
You need a good old fashioned tune up, that means new plugs and wires.
I prefer Iridium plugs but you must use Magnecor plug wires, if you dont you will be doing the job again in a couple of months.
www.apexperformance.net has the best price on them.
Old Nov 22, 2009 | 09:31 PM
Hennessey's Avatar
4th Gear
could it be a head gasket?
Old Nov 22, 2009 | 09:48 PM
Hennessey's Avatar
4th Gear
The codes are: P0103, P0171, P1300, P0305, P1171, P0303, P0300, P0301, P0307
Old Nov 22, 2009 | 09:49 PM
Hennessey's Avatar
4th Gear
wires and plugs appear to OEM, I checked the #5 plug when the problem first started, no fouling, oil or burnt parts
Old Nov 23, 2009 | 06:12 AM
lipadj46's Avatar
No if you had misfires in just 1,2,7, or 8 then you would start thinking head gasket. Start with a tuneup clear the codes and see what comes back.
Old Nov 23, 2009 | 08:33 AM
OEM is not good enough any longer. get soem Bosch +4 platinums or what those other guys use Iridiums and some 8mm Magnecor wires. also might wanna try doing an induction cleaning and clean the throttle body. clear the codes drive it and see if anything comes back. i bet not.
tigertrakstar1
Mar 5, 2014 04:13 PM
Ad!
Nov 28, 2011 10:06 PM
Jameslandrover110
Defender
Feb 18, 2011 02:46 PM
RTWoerner
Jun 13, 2007 11:22 PM
bksy1
Freelander
May 23, 2005 01:18 PM
