Still misfiring, any suggestions?
Old Nov 28, 2011 | 04:11 PM
Ad!'s Avatar
Ad!
Default Still misfiring, any suggestions?
Hi everyone, i recently posted on this forum because i was having misfires on the whole bank a. I ended up changed my spark plug wires with kingsbourne 8mm wires and i also changed my spark plugs with some cheap ngk replacements.
Before changing both of these parts i was pulling codes
p1300
p0300
p0301
p0303
p0305
p0307
p0174
p0130
p0150
Now im getting
p0305. I also have p0307, p0130, and p0150 pending.
My truck is a 2000 discovery ii with 130000 miles under the hood. also i recently had a head gasket job done because i had coolent in my oil. I already plan on changing all four o2 sensors i just cant wrap my head around this misfires... Any suggestions?
Old Nov 28, 2011 | 05:41 PM
Re-check plug wire route and connections - sometimes plugs wires get swapped...
Old Nov 28, 2011 | 05:54 PM
Ad!'s Avatar
Ad!
Will do tomorrow but is there any other suggestions you might have? This has been going on for 6+ months and im really trying to solve this
Old Nov 28, 2011 | 05:59 PM
jafir's Avatar
Is it like a dead misfire, where it misses all of the time? Or do you not really notice it, except that you get the check engine light?
Old Nov 28, 2011 | 06:14 PM
Ad!'s Avatar
Ad!
It misses every once in a while but not dead. Runs much smoother after changing plugs and wires but I still get that misfire. Before tune up my motor was shaking horribly but now seems to be running much better. Im planning on cleaning my maf sensor tomorrow, will post results
Old Nov 28, 2011 | 10:06 PM
P0130 and P0150 are codes for front O2 sensor short circuit, wiring or connector issue.
Scott Weiland
Oct 16, 2013 01:15 PM
Hennessey
Nov 23, 2009 08:33 AM
grussell
Dec 15, 2008 10:03 AM
gfeehan
Sep 1, 2008 09:41 AM
gfeehan
Aug 29, 2008 08:44 PM
