Miss fire?
Old Mar 25, 2008 | 07:36 PM
mitsi88's Avatar
Default Miss fire?
Hi all,
On starting out on a recent return trip, having already covered 450km the previous day,my 1997D1 v8 3.9i developed a slight but very noticable miss; particularly noticable on hills etc. It slowly got better on the trip home to the point where its just a minor miss now, but perfectly ok.
What are the likely causes; water and oil are fine so no head gasket problem. I suspect electrical; the leads are quite thin black ones which dont look too flash. Distributor cap/rotor maybe or coil?
A possible related issue is a slight ticking noise (not dissimilar to the sound you get if you test a spark plug while attached to a lead but removed from the engine) where the HT lead passes the power steering fluid contianer - I pulled the lead away from the fluid container and the sound decreased. I replaced the HT lead with a good replacement one, but the sound persisted. Any ideas on this weird one - coil shorting??
Cheers!!
Old Mar 25, 2008 | 08:18 PM
Default RE: Miss fire?
I would say that you need a tune up. New spark plugs and wires. Are you sure that you have the 3.9L? My '97 has the 4.0L engine.
Old Mar 25, 2008 | 09:35 PM
mitsi88's Avatar
Hi
Will replace the leads and plugs i think. Definitely a 3.9, says so on top of the engine! Its japanese/Australasian spec. Im in NZ, we only have the 2.5 300 TDI and the 3.9 v8i in the 1989 to 1998 Disco.
Cheers
Old Mar 26, 2008 | 08:51 AM
When you are done with your tune up, plan on doing an induction cleaning tto decarbon the engine, this will make a huge difference for you as the 97's were know to carbon up the valve stems.
narleyman63
Jun 24, 2010 10:11 AM
Buzz09
May 8, 2010 04:21 PM
tommytwotone
Oct 26, 2009 10:59 PM
allstarbiker592
Mar 14, 2007 11:41 AM
04DISCOINHR
Feb 28, 2007 12:05 PM
