Miss Fire
Miss Fire
Same problem. Runs rough, many codes, raw gas smell. New plugs, new wires, STI. Front 2 O2 sensors replaced. I have raw gas smell from exhaust. Pulled plug, raw gas on plug. All plugs are getting fire. Its seems to be getting way to much gas at all rpm's. Codes P1319, P1300, PO300, PO301,PO303, PO302, PO306, Po308. Does run, but runs to bad to drive Need help.
I had this same problem on my ex fiancee's camaro. It was shooting raw gas from the exhaust. I changed the cat twice all the O2 sensors, the MAF, plugs even the computer and never figured it out. It always through a Cat code which made sense because of all the fuel being sent through it. It has to be a sensor some place. I always wondered if one of the female connectors was bad or dirty. I thought about that after we parted ways. She traded it in and never told them about the problem. Can you test the female connections? I had changed both up and down stream O2's and thats what I was sure it was but I never checked to see if the reading was making its way back to the computer. I cant see like Mike said said both coil packs going bad, if both were bad all 8 would misfire. You are misfiring on 6 cylinders and your cat is drowning in fuel. So something is not sending the proper mixture info to the computer so its just dumping fuel. It has to be a bad connection but Im far from an expert. Did you trace the wires back looking for issues? Maybe some carb cleaner on the connectors??? Dont know if this will help but its my 2 cents.
Akumal when you put the plug wires on the coil did you feel them almost snap onto the coil? Might be a dumb question but are you sure you put the right plug wire on the proper coil? I only ask this because after I did mine I was having the same issue and Mike asked me if I had the right order so I took them off again and redid them and problem went away. I must have something crossed up. Not sue how you did yours but I did mine the blind way and left the intake on.
