Missing Bolt, help!
Old May 24, 2014 | 09:06 PM
Francopacks's Avatar
Default Missing Bolt, help!
After tearing down the front of the engine, I noticed that is a bolt missing. The bolt is the one that holds the coolant pipe onto the bracket below the alternator. Anyone have any idea what size and length bolt that is?
Old May 24, 2014 | 09:14 PM
RoverMasterTech's Avatar
8mm 1.5. about 15mm long. Same as the power steering pump/water pump pulley bolts. pull one of those out to take to lowes with you.
Old May 24, 2014 | 09:18 PM
Perfect, thanks much. I have no idea how that could have fallen out or gone missing. Crazy.
Old May 24, 2014 | 09:54 PM
jfall's Avatar
Bolt either bounced or rolled away on the floor.
Or it usually ends up in the plastic tray below the fan.
Old May 25, 2014 | 11:11 AM
SuperSport's Avatar
Is it possibly broken off in there? It seems like I might be looking at it inside the hole. But I could be wrong from the photo being a little far away.
Old May 25, 2014 | 12:36 PM
That's a good point, it could be snapped off in there. I didn't look that close. I'll check it out.
Old May 29, 2014 | 10:10 AM
I looked closer. The bolt is not snapped off. It looks like a prior mechanic just left the bolt out because the bracket doesn't quite line up to the bolt hole making it impossible to get a bolt in there.
Old May 30, 2014 | 08:52 AM
SuperSport's Avatar
That's good. it can sometimes be challenging getting those out.
newpassion
Apr 12, 2014 03:36 AM
etsZac
Jan 5, 2014 04:05 PM
focusontheworld
Oct 21, 2012 01:00 AM
jgbasham
Freelander
Oct 25, 2008 04:11 PM
JEFF
Apr 19, 2007 09:47 PM
