Missing Front Drive Shaft
Old Apr 7, 2019 | 08:48 PM
mollusc's Avatar
Originally Posted by Jeff Blake
Get under the vehicle and make sure the two CDL switches are plugged in and working, the cable is attached, etc. I'd want to make sure I could unlock the transfer case before putting in a front D/S
^^^ THIS. you do NOT want to have both driveshafts installed and then drive too much on surfaces with no slip. the transfer case cannot handle the differences in rotation between the front and rear axles for long when the case is locked.
and if you've been able to drive with no front driveshaft, then your case must be locked.
Old Apr 8, 2019 | 07:07 AM
Red5's Avatar
Originally Posted by Nosugar0carbs
I keep it pulled and in the cargo area for the trails. I could get the discovery sideways in the rain with 31” wheels, pretty interesting.
You install the front shaft ONLY if you plan to go off road? Why?
Old Apr 8, 2019 | 07:50 AM
Nosugar0carbs's Avatar
no hills or ice/snow in FL. I don’t see a need for a perm. 4 wheel drive other than off roading.
Old Apr 8, 2019 | 10:08 AM
NewToTheTwo's Avatar
Hydroplaning can be a bitch though and God knows it rains in Fla.
I'm pretty confident theres just no reason NOT to leave it on.
You're creating extra work for yourself for what purpose?
Old Apr 8, 2019 | 12:21 PM
jastutte's Avatar
not to mention a lot of added stress to parts that were designed to share the load.
the Discovery drivetrain was designed to distribute load from the engine to TC and from the TC to front and rear driveshafts and differentials. when you remove 1/2 the parts from that you are asking the remaining TC output, driveshaft and diff to compensate.
Old Apr 9, 2019 | 03:19 PM
stefanas's Avatar
I will check for the CDL switches, need to research on where to find them. Ordered a FDS from Lucky8. Thank you guys!
328Driver
Aug 31, 2017 05:20 AM
tflem1
Aug 22, 2012 12:56 PM
zukilj20
Jul 31, 2011 04:20 PM
scottma
May 19, 2011 07:34 AM
BMWLR
Sep 28, 2006 10:33 AM
