Chirp in Drive Line
Old May 15, 2011 | 05:41 PM
scottma's Avatar
4wd High
Default Chirp in Drive Line
I just installed an OME 2" lift kit. Mty drive shaft now chirps. I lubricated the front portion with inserts but it did not help. Any ideas. Has anyone heard of this type of issue before?
Old May 15, 2011 | 06:13 PM
Your double cardon is bad and about to break.
Tons of info on this if you search the forum for it.
Do NOT drive the truck until you get your front prop shaft rebuilt.
Borrow a car if you need to get to work tomorrow because when that breaks you WILL be buying a new transmission.
Old May 15, 2011 | 06:21 PM
DiscoRover007's Avatar
Spike, he could lock the CDL right and drive it?
Old May 15, 2011 | 06:44 PM
Only if he removes the front prop shaft.
But yes, as long as you remove the front propshaft you can lock the CDL into hi and drive your truck.
EDIT:He can only do this because he has the lockable CDL on the transfer case because it is a '04.
Old May 15, 2011 | 08:09 PM
jafir's Avatar
I wonder what kind of burn outs you could do in lo with only the rear driveshaft......
Don't consider this as a suggestion to TRY....
Old May 15, 2011 | 11:13 PM
sloan74's Avatar
/this
Mike told me the 3 amigos will cut on, so if you decide to go this route don't panic about those. They will cut off once u reconnect the shaft.
For sure do not drive it until you get the driveshaft rebuilt. That chirping noise it a bomb tick. That thing breaks while driving fast and your looking at 2-3k for a new transmission.
Old May 19, 2011 | 07:34 AM
Banzai Jimmy's Avatar
In the Jeep world, they call that the "angry sparrows". As everyone else said, don't ignore it and get it fixed ASAP.
Jared9220
Aug 20, 2014 10:22 AM
akanigit
Oct 11, 2010 06:32 PM
CampCobb
Jul 20, 2009 06:49 AM
Randy P
Sep 27, 2007 08:27 AM
GrnDisco
Feb 12, 2007 08:19 PM
