Moisture behind headlights
I've got a 2003 LR Discovery SE7 and I have a persistent problem with condensation behind the plastic headlight covers (see attached photo). A few months ago I took everything apart, removed the bulbs and let the cover dry but after about a week the moisture was back. Is it the seal around the bulbs??
Thoughts? Cheers.
Jason
[IMG]local://upfiles/10665/06501FDC59F84EAABAF289AD7DB217C3.jpg[/IMG]
Thoughts? Cheers.
Jason
RE: Moisture behind headlights
This is a common issue with those style headlights. There should be some drain tubes on the back of the unit, it's possible they have become clogged and won't drain. Others have drilled small holes on the lens to let the water evaporate out. That wouldn't by the solution I'd want but if it works...
ORIGINAL: Jupiter Rover
Drill holes. I am about to drill holes in mine. Same problem.
ORIGINAL: Spike555
Drill a hole on the highest part of the headlight too so that you get a cross flow of air.
When the water evaporates it will go up, when it condeses it will pool at the bottom.
I too have done this on other cars.
