Moisture behind headlights
Old Oct 8, 2008 | 01:53 PM
jay040472's Avatar
Default Moisture behind headlights
I've got a 2003 LR Discovery SE7 and I have a persistent problem with condensation behind the plastic headlight covers (see attached photo). A few months ago I took everything apart, removed the bulbs and let the cover dry but after about a week the moisture was back. Is it the seal around the bulbs??
Thoughts? Cheers.
Jason
[IMG]local://upfiles/10665/06501FDC59F84EAABAF289AD7DB217C3.jpg[/IMG]
Old Oct 8, 2008 | 02:00 PM
brooksa's Avatar
Default RE: Moisture behind headlights
Mine did the same thing about 4 months ago, I removed the light and just dried it out with a hair dryer, have not had any problems since then.
Old Oct 8, 2008 | 02:03 PM
jay040472's Avatar
So perhaps I didn't dry (remove) all the moisture the first time I tried?
Old Oct 8, 2008 | 02:10 PM
Disco2Guy's Avatar
This is a common issue with those style headlights. There should be some drain tubes on the back of the unit, it's possible they have become clogged and won't drain. Others have drilled small holes on the lens to let the water evaporate out. That wouldn't by the solution I'd want but if it works...
Darover's Avatar
Check again for crack in the housing if you find some, try applying some plastic plumbing glue. If you find no cracks, apply some synthetic grease on both sides of the seal around the bulbs. After completely drying the lights of course !!!
Old Oct 8, 2008 | 04:29 PM
Supposedly there is a seal kit to fix this problem, but I have not seen it.
Maybe somebody else knows what I am talking about and can post a link or something.
Old Oct 8, 2008 | 04:33 PM
Jupiter Rover's Avatar
Drill holes. I am about to drill holes in mine. Same problem.
Old Oct 8, 2008 | 05:09 PM
CandiMan's Avatar
ORIGINAL: Jupiter Rover
I gotta jump on the band wagon. Drilling a hole will not affect the operation of the lights. I've done it on personal and company vehicles for many years. Drill at the lowest part of the headlight.
Old Oct 8, 2008 | 05:25 PM
Drill a hole on the highest part of the headlight too so that you get a cross flow of air.
When the water evaporates it will go up, when it condeses it will pool at the bottom.
I too have done this on other cars.
Old Oct 8, 2008 | 07:55 PM
ORIGINAL: Spike555
Good call! Thanks, I didn't think of that.
LeakyDisco
Apr 7, 2025 04:34 PM
kman35ca
Nov 27, 2011 09:16 AM
ALEXAN
Aug 30, 2009 11:31 AM
jay040472
Jun 24, 2008 12:44 AM
newdr
Jul 23, 2007 10:13 AM
